Help!
put your new files into a folder.
Thanks for that quick response! Actually, I saw a brief message saying that the file had been successfully created.
Here’s how it looks.
But here’s what appears on the OP-1 screen.
No user folder.
Weird(er) thing is that the only file that I placed in the user folder is the ‘aj basic.aif’ file. I don’t know where those other .aif files came from.
@jessetal This may/may not work but when you are on the same screen as your screenshot above hold shift and press the 8/M2 button and this should reveal another folder (probably called ‘snapshot’) which should have your file inside.
@jessetal The 8 .aif files in the user folder are whatever is saved onto the 8 preset buttons. If you put your own files in a new folder or in the snapshot folder they should show up.
@jessetal, since you’re an OSX user, in case you find it useful for the future, you can take screenshots with Command+Shift+3 or 4. With 3, it captures the entire screen; with 4, it gives you a reticle to choose what you wish to capture either with the mouse or by pressing the Space bar, which is context-sensitive–so if you hit Space with the reticle over Finder, it will take a shot of only Finder.
Drum Folder -> Your Folder = put aif file in Your Folder @jessetal
Hey there fella!
I too had the same query and marched around Internet for quite sometime and then I came across a website by a French recording engineer. His name is Julian Tauban and he has provided many a sample specifically aimed at our beloved toy of joy - the Op-1. In one of his manuals he describes the process in a simple, easy to understand manner. Although I haven’t tried it yet I’ve taken some photos of the screen shot in iBooks. I tried to locate the Internet file but I couldn’t find it again. Anyway, let me know how you get on @jessetal;
This works perfectly… !
