anybody else having trouble getting a revised drumbank with the same name updated thru the app into the op-z
iow still playing the old version
a delete function in the app would be great
Yes, it doesn’t update when the name is identical. You can rename it or remove it and replace it after a power cycle. In both cases, the projects lose their reference and you have to redo the settings for the updated drum bank. I’ve reported this to TE in December because I think it’s a huge bother; you’d have to prepare 24 drum kits at once to use the space in a sensible way.
