Hi all, I’m trying to record EP-40 (Riddim) patterns into Bitwig as MIDI and have run into something odd. Wondering if anyone else has seen this, or knows a workaround.
Setup: EP-40 connected to a Mac over USB-C. MIDI channel setting is “all” (110). Pads have no MIDI channel assigned in sound edit. I’m watching with Snoize MIDI Monitor.
What I see:
When I play the pads by hand, the EP sends the correct note-map notes on ch 1. Pad 4 (closed hat) = note 42, pad 6 (ride) = note 44.
When the sequencer plays the same pattern back, every pad comes out as note 60 (C4 in EP naming), ch 1. This is the default root note. The hat and ride are indistinguishable over MIDI, and there are overlapping Note Ons without matching Note Offs.
It’s easy to reproduce: clear a pattern, live-record a few hits with MIDI Monitor open, and the first pass shows the right notes. As soon as the loop comes back around, everything is note 60. It sounds correct on the EP itself. Only the MIDI out loses which pad played.
I measured this on my EP-133 (OS 2.5.1), so with the EP-40 caveat below. As far as I can tell, the sequencer doesn’t send the pad’s note-map note, it sends the pitch that was recorded into the pattern. Drum hits are recorded at the pad’s root note, so they all come out as 60 and look the same. It depends on the global MIDI setting (SHIFT+ERASE, code, ENTER):
110 (display ALL): live hits send the manual’s pad notes (36 to 83) on channel 1, so they look fine, but pattern playback sends every pad’s recorded pitch on channel 1. That’s exactly your symptom.
127 (display OFF): only pads with a MIDI channel set in sound edit send anything, and the sequencer sends each pad’s notes on that pad’s channel.
What worked for me: set 127 and give each drum pad its own channel in sound edit. Then Bitwig can tell them apart by channel (one track per channel, or one track on all channels and remap by channel to the drum notes you want). Live hits send the root note on the pad’s channel as well, so recording and playback match.
I haven’t tried this on an EP-40, so I can’t promise it behaves the same, but it’s the same family. I didn’t look closely at the missing note offs, so no idea there.
Thank you. I think this matches up with what I am seeing. I found that if I edit the sounds on my drum pads e.g. go to the MIDI setting for that pad / sound. I can set the root note to any note that I want. (I’m just setting it to the same note that the MIDI map has associated with that pad in that group).
Then, whether I’m playing live or playing back a pattern, what gets sent out MIDI Channel 1 is the same and matches with the note map for that group.
Nice find, that’s simpler than splitting everything across channels, and you keep the whole kit on one channel in Bitwig.
One thing to watch: if you ever record a pad pitched up or down (keys mode), it will come out as an offset from the new root note, not the note-map note. For straight drum hits it shouldn’t matter.
Did the overlapping Note Ons without Note Offs go away with this, or are they still there?
So my drum pads, I keep them set to MIDI off. That puts them in the general mode where they receive everything on the general MIDI channel and send everything out the general MIDI channel.
When they are in that mode, setting the root note determines which note gets sent out channel 1 MIDI-wise. If I put a particular pad into keys mode it stops sending anything at all out MIDI-wise. For samples that I want to play chromatically, I don’t set their MIDI setting to off, instead, I assign a channel and in this case appropriate notes get sent out MIDI-wise as I move up or down the scale. And yes, to your point, changing the root note changes which notes are being sent out in that case.
Thanks, that’s a clear write-up, and it fills in the part I hadn’t tested: a pad in keys mode going silent over MIDI when its channel is off. So for anyone who finds this thread later:
Drum pads: MIDI channel off, root note set to the note-map note for that pad. Live hits and pattern playback then both send that note on channel 1.
Pitched pads: give them their own channel. Notes then follow the scale from the root note, live and from the sequencer.
That’s a neat way to keep a whole kit on one channel in Bitwig.
I’ve also sent the original issue to teenage engineering as a bug report: under 110, pattern playback should send the same note-map notes as live hits. If it bothers you too, a short note to support@teenage.engineering helps; they track how many people ask for the same thing.
