EP133 midi out issue
Hi
I have an EP133 with which I made some beats that I wanted to transfer to my DAW. Unfortunately, it seems that all the pads send the same note… which makes things impossible to use.
I tried to assign them independent MIDI channels, but it’s complicated and you have to filter everything at the output.
On the other hand, with the OPZ, no problem, each note of each track is exported correctly.
Is there a solution for this?
u prolly gotta change the midi root note for each pad?
