The pico trigger would be a nice addition to my Eurorack. It can be clock master but also take a clock and sync to external clock.
The clock sync out of the op-1 is sometimes too quiet/wrong level to work with every module: the make noise math or function will sync to the op-1 the Pamela’s workout and the delptronics trigger man will not. Anyone tried the pico trigger?
somewhat unlikely.
Yes the MI ears works perfect as a preamp but in this case I want to use only modules that only use the +12V. Like pressure points, Rene, Erica trig etc.
Trigger-Module arrived today (needed it anyway) and the op-1 clock is too quiet. Erica Synths suggested to use one of their scale modules to get more voltage out.
hi @dinraum!
did you find a way to receive clock form the op-1 into your trigger from erica synths?
I have a midi<->clock from erica synths and I can’t get clock input from my op-1.
DIt looks like the OP1 sync Signal is too quiet. You have to use a preamp like the mi ears or the middle channels of a Maths to boost it.
that’s what I thought thanks for your reply!
I have the ears. Is it a case of taking audio out of the headphone socket into ears and setting the OP-1 as… how does this work
Yes. If you set the OP1 to po sync it outputs a clock signal on one channel. Be careful with headphones and this mode. You need a special splitter cable to separate the clock from the mono channel.
There is one tractor dj cable that should work. But I also have some signal bleeding. I think you need also a stereo cable or have to solder one by yourself.
I use a SISM by 4ms, and I also use two types to splitters.
The Red/Black Hosa with tip/ring markings, and a multiple so I get copies after the SISM
amplifies the signal. On a scope OP1 trig is around 1V or so and most modular gear needs at least 2V.
Are those red black hosa cables not just simple stereo?
Yea its stereo to 2 mono split L/R. That way you can have audio on one and trigger on the other, I think tip is trig. Same with the input. You can clock it from external and the splitter will allow one to be trig in and one to be audio in.
