Fellow operators, shalom.
I recently got a FH2 to be able to use my main sequencer op-z with my Eurorack skiff. The fh2 configuration seems straight forward, tho I’m not getting it right.
I’ve been searching for configs or screenshots of different configs to no avail.
Basically I need to know the relation between converter outputs and chosen functions for the given midi channel. For example;
Enable 1. Midi chan 3, gate, cv.
Obviously the gate and cv needs their separate outputs, do I need to enable converter 2 and enter midi chan and check the cv box, or can I leave converter 2 disabled so converter 1, based on checked functions, claims converter outputs under it?
A side note when using gates only is that it looks like some gates are stuck and that some gates or trigs are lost. Surely due to inadequate setup on my part so any help about this is also very welcome.
