Hey ya’ll!
No idea sorry. I’ve never actually created patches this way, only ever used line in or the drum utility. Curious what the issue is though, may try this myself.
I wonder if everyone else who has created patches did it inline, saved into their snapshot folder, then renamed from there?
Not sure if relevant but when I recently tried to rename and save user synth presets via back and forth to computer I got a bunch of ‘failed to save’. Turned out I was being an idiot and hadn’t deleted the original ‘pre-naming’ snapshots, so I was basically trying to store copies of loads of onboard snapshot patches and I was hitting memory limit…
Looks like you have a bunch of synth sampler patches already onboard in those juno collections etc. Have you maybe reached the memory limit for total synth sampler patches? I think that’s 42 patches.
If that’s not the problem then yeah, I guess there’s some meta data or something written internally on OP that is necessary for a file. Maybe you could use the drum utility software?
I tried removing all other non-stock synths and still getting the issue.
I tried removing all other non-stock synths and still getting the issue.My current assumption is that if the patch isn't created on the OP-1 or with the drum utility, there's going to be failure issues? I'll try and make patches through line in later.
Yeah seems that way. Tho confused why TE would suggest you make a video if it was a simple case of ‘patches need to be initially created internally on OP or via the drum utility’? Wouldn’t they just have told you that if that’s the case? Why the need to make a video after you described your process/problem if the explanation is that obvious?
Beats me!
No, samples can be prepared as aif files on an editor, I just don’t know the settings. Suggest that you load another sample into your editor, paste a piece of audio over the top, then “save as”.
Okay, so I just tried ghostly606’s suggestion.
Are you sure you are not using AIFFs instead of AIFs ?
For reference (I believe this was already mentioned earlier), these are the limits on patch types. It’s very easy to overload on Juno (or Shruthi, in my case) patches and then get that “unable to save/create” error. So if you have 42 sampler-based patches, you can erase every other synthesis patch and you still won’t be able to add more.
Max Synth Sampler patches = 42
Max Synth Synthesis patches = 100
Max Drum Patches = 42
