Featuring 4 multi-sampled piano instruments which you can load using a drum (sampler) channel and 55 single-sampled instruments which you can load using a synth (sampler) channel for a total of 59 sounds!
Field Modulation contains various sampled sounds with a focus on early / vintage digital synthesizers like the Yamaha DX FM synthesizers, early samplers and romplers combined with modern effects for that nostalgic, but also fresh sound.
All Patches are crafted with great care using (multi) samples of my personal sample library so these are not just simple presets, but custom sounds.
Here is a simple patch play through which I hope you’ll enjoy. Cheers!
Ps. Make sure to check out my other OP-1 Field sound pack ‘Field Broadcast’ as well
The ‘drum’ samples are not backwards compatible with the OP-1/OP-Z, but the ‘synth’ samples will import, however they will get converted to mono obviously and will loose most if not all of the sample/adsr/effect/lfo settings so I advise against it for now.
I am also slowly working on a OP-1 OG sound pack and those samples will be compatible with the Z
I also have 2 sound packs for the OP-Z already available, but I guess you already know?
