I have a Zoom H2n that lasts up to 20 hours on two AA/LR6 batteries (and can be calibrated for 1.2V NiMH, too). 4 mics for a bit of surround if you want it, uses SD memory, has line in and line out, some basic effects (dynamics), analog gain control, tripod mount…
thanks krism, that would confirm my theory that i don’t need to spent too much money
i mainly want to record ambient, athmospheres, soundscapes, noises and that stuff to sample and use it later in my tracks …
any other experiences?
I totally lied to you about MP3 recording, the other options were for 16/48 and 24/48 >.>
I come a video production background and I use an H4n extensively. Its a great little recorder!
I used an Edirol R09-HR for awhile, very simple to use and the sound quality was better than I expected. Downside was that there wa sa lot more handling and wind noise than I expected, which I’ve found true of most of the smaller hand held portabel recorders. Also, it never felt that discreet, at least in the city, maybe not an option in the mountains.
+1 on a smartphone for “in the moment” capturing. My first ever field recording experience was with an iPhone 3GS and Blue FiRe (the free version of FiRe).
The onboard mics on the H6 are great. And the preamps sound very nice to me, as do the converters. It’s a bit big to be spontaneously put in your pocket, thus might end up not being brought with you, but in terms of sound quality it’s very good. It doubles as a USB audio interface, and also as a battery (or usb) powered compact 6 channel mixer. Also there’s the option to remove the mics and put an extra set of two xlr inputs. It’s good.
Check out this youtube channel: https://www.youtube.com/user/greenhiphop/videos
thanks guys for the hints and tips.
for the “in the moment” recording the iphone sure is a solid backup.
in fact with this idea in mind i bought a tascam iM2 mic a while ago – but it turns out, especially for quick spontaneous recordings it is not practical (plug the mic in, start the app, hope the mic is recognized, turn of autolock, turn on flightmode, etc) and kept me from doing recordings in the first place.
the zoom h5 seems like a good in-between option. thanks for the hint! i will look into that one (it’s not a beauty though
i will check out the video after work, thanks!
with the h6, I have a 6 channel audio recorder, with 2 onboard mics and 4 inputs?
and does it to either the computer or an SD card? at 24/96?
the H6 also has a $70 pair of combo jacks (like the 4 built into it) you can swap out instead of using the mics it comes with @dimi3
I’m with Tarekith - if you’ve got an iphone/ipad/ipod then you can get some pretty decent field microphones that you can keep in your pocket alongside your device and plug-in and record when needed.
It’s too bad Rode still doesn’t have a lightening version of the XY mic, man that thing was awesome.
Thanks everyone for the comments and hints. I will not pull the trigger yet, let’s see …
I did on an h6 it is awesome! best portable system I have seen in a while. 20 hours on 4 AAs 64gb card gets you 20 hours of recording at 24/96…
this is a midnight jam… slightly heavy handed… Analog Rytm only mains out to a H6 in 24/96
https://soundcloud.com/dimi3/midnight-jam
Rode iXY mic now has a Lightning version: http://www.ixymic.com
