Fine Control Encoders (one click=one increment of change) in Ableton with Imaginando remote script?
Hello all! For those of you who use your OP-1 as a controller for Ableton, do you know of a way to control various fields in Live with the colored encoders on the OP-1 with a sort of “fine tune” control like in normal OP-1 use (shift + turn encoder) to have one click on the encoder dial be one increment in the field?
Currently, it auto-assigns itself to have the whole spectrum of increments (-128 to +128 most often) spread over about 32 clicks, which has it skipping about 8 increments per click, instead of 1 increment per click.
For anyone serious about making fine adjustments to things such as volume, pan, and basically all dials in the program this is a pretty serious flaw.
Thanks for any advice!
Does it really? I’ll check it out.
The other problem is that encoder is mapped for a relative value change (the script detects only -1…1) and this may cause this behaviour.
Fine control with i.e. shift should be easy to implement.
Would you mind filling in a feature request to:
https://github.com/pcppcp/op1/issues
