TE being TE again, new update since the end of March, but it’s only visible via the “patchnotes” site.
Was the same with the vocoder update…
https://teenage.engineering/downloads/op-1/field
In case you missed it.
Thanks for posting, I hadn’t seen this.
Has anyone noticed that the OB-4 does not connect Properly with the new update?
Over here it connects fine with the Ob-4 with the latest firmware on both.
I keep trying to to turn the parameter on the op-1 field to adjust the channel on the ob-4 with no success. If I go back to the 1.4.3 update, it works fine, but the 1.4.5 doesn’t work for some reason.
