Found bug and issues
Bug:
When live record an accord (start record with note, not count-in) and when record again to add some notes (overdub), the first step only the new record will be save, this bug is only in step 1.
Issue:
I can’t edit notes over more octaves, if holding step then using -/ +.
An idea to TE could be to add Shift + (±) to nudge step , so +/- works as octave shifting, even with step holding down.
The is no way to add new notes in a accord on a step (workaround double press existing notes and then it works, but it will be problem if using track scaling and a note is nudged),
My biggest problem is : only 120 notes, very difficult to create piano house or classic music, and no warning either, it just cut the rest notes.
I cant see any reason to limit on 120. 255 is better. Also need 8 bars to skip track scale evertime. TE just make the bar icons smaller.
Perhaps there are more with the same problem. Then a question, that you say about to add SHIFT+ (+/-) to nudge a note instead of just use +/-?
I have reported and send a video on the bug with record overdub, TA look at it, probable fixed in next version.
