It should be simple right?
i am quite new to the op-1, but really struggling with this. i am simply trying to connect the beat step pro to the op-1.
Yes I watched all the tutorials and they all seem to use this iconnect midi box.
Since then this company updated this box and REMOVED that standard USB port on the front-center that conveniently connected to the op1.
I purchased this newer iconnect midi instead
but it does not seem to be working at all likely because of the bizarre connection have to make from that female-usb-mini port (far left of image) to the op-1
does anyone know how this can be accomplished without trying to acquire one of the older obsolete iconnect MIDI devices or the 300$ oplab? did anyone have luck getting one of the newer iconnect midi products to work? was anyone able to connect the beat step pro to the op-1?
Thanks in advance!!!
but it does not seem to be working at all likely because of the bizarre connection have to make from that female-usb-mini port (far left of image) to the op-1does anyone know how this can be accomplished without trying to acquire one of the older obsolete iconnect MIDI devices or the 300$ oplab? did anyone have luck getting one of the newer iconnect midi products to work? was anyone able to connect the beat step pro to the op-1?
