Hey, trying to go straight from Guitar into the op1 direct in and wondering what adapter I need. I bought a 1/4” to stereo 3.5mm adapter but I’m only hearing my guitar on the left side. Do I need a 1/4” to mono 3.5mm adapter? I don’t really care about quality so not looking to use any other gear/amp/pedal
Guitars are mono instruments, guitar cables typically don’t carry a stereo signal for this reason.
You could run into a stereo pedal, use an a/b/y switch in y mode or use a headphone amp.
Really don’t want to add anything extra to the set-up. I dont care about quality it’s literally just so im able to hear what im doing down the centre rather than panned L or R. Would a TS 3.5mm cable like this not work? https://www.amazon.co.uk/Cable-Ancable-3-3ft-6-35mm-Cables/dp/B07ZNHJ5S6/ref=sr_1_4?crid=3LT3ZG8MRHGGT&keywords=ts+to+3.5mm&qid=1659304634&sprefix=%2Caps%2C75&sr=8-4
No, that’s a mono cable passing a mono signal. You need to create a stereo signal with a stereo pedal or duplicate your mono signal on both sides of the stereo field with something like an a/b/y switcher.
So in this vid - OP1 Tutorial: How to use your guitar or bass with the OP1 - YouTube
He uses the adapter I bought with seemingly no issue. Albeit it’s with op1 and not OP1f but does the op1 only accept stereo input?
One of the main features of the OP-1f is how it’s stereo throughout the chain, while the OG-1 is not. So that’s why you’re running into this issue.
Stereo vs. Mono. Main upgrade from og to field is stereo.
gotcha gotcha - thanks!
some 1/4" TS (mono) to 3.5mm TRS (stereo) cables have the mono signal connected to both tip and ring on hte TRS side. but some do not and they dont really tell u if they do or not.
u could also look into a splitter adapter that will do this as well
that splits the L & R and connects the L to both the tip and ring on one side of the splitter and the same for hte R on the other side of the splitter
so like L & R to LL & RR
or some 1/4" mono male to 3.5mm stereo female adapters will connect the mono signal to both the tip and ring on the stereo side as well
u can def do this w/ the right cable and // or adapter plug
I know you didn’t want to add anything, but I’m gonna throw this out there: Mustang™ Micro | Guitar Amplifiers
I also recommend the Mustang micro.
Could you not just… pan the channel in the mixer?
i thought this too
but i think that when u are on other screens besides the tape or mixer
that the pan defaults back to center if im not mistaken?
so this would only sorta work if that was the case
I just tried it and it sounds terrible. I used a mono 3.5mm to mono 1/4in cable, and it worked, but as expected the impedance mismatch gives a weak signal.
The Field has plenty of gain, but can’t make up for the thinness.
Yeah, gotta double up that signal. Mono doubled to stereo.
Hey all!
First timer here.
Saw you guys recommending the Mustang Amp. Gotta ask - how does it connect wirelessly to the OP1 Field? Pardon my candidness…
Gonna leave an answer here in case someone ever ask the same thing : recording via the mustang amp is an USB-C affair.
Since this thread is now awoken, in a firmware update at some point the 3.5mm stereo input can now be set to MONO so the single records to both channels. I use this for the microfreak, which is mono.
lmao I just read through this like “why is no one mentioning mono input” then I read the date
@Heyes the op1 and field DO NOT have wireless capabilities outside of BLE midi and the FM radio. It won’t even do bluetooth audio to the OB4 - so if you wanna do wireless you’re going to need a traditional guitar transmitter added into the system…or just use a cable.
