Guys please help me with uploading samples onto my OP-1
#1
So I’ve been doing a lot of digging and I found this helpful video: https://www.youtube.com/watch?v=Gw1n4p8As-Q … the problem is I have a windows PC and I do not know how to load these on in AIFF format. Can you guys let me know how you Windows PC’ers get samples onto your OP-1?
#2
If you follow the video instructions to about 0:23 then in your windows computer, the op-1 should show up like a usb drive. From there you can drag files into your op-1.
op1.fun is a great site with a ton of samples already to drop into your op-1. They have their own drum utility you can try. https://op1.fun/drum_patch_builder
You can find the op-1 drum utility here https://xferrecords.com/freeware/
If you need a good open source (free) tool to convert your audio samples into the aiff format audacity is there for you. https://www.audacityteam.org/
#3
THANK YOU! I could not find a good program for changing to AIFF. I will be getting Audacity ASAP. Happy Thanks Giving!
