Hello everyone, I am looking for a mobile headset solution for
op1-f. As far as I understand, this is solved with a wired headset. Or is there a wireless solution that I am missing? I could not come to a clear conclusion. I would be very happy if those who have experience share their ideas. Thank you
The device does not support wireless headphones. I’d recommend wired ones only. You could do wireless if you got a bluetooth dongle from the audio out it would add latency that would not be a great experience.
Yeah, having a wired headset is the way to go. I sometimes use my Shure in ears.
It is unfortunate that there isn’t a good bluetooth option without latency yet. It makes it very hard to play if you use a BT dongle. Kind of OK on the OP-XY step sequencer etc but not really for the OP1/F.
You can go wireless sort off
Use the fm transmitter
Use a pocket transistor radio/your smartphone. with a headphone
Thank you very much for your interest and response. @fallen_lassen @JaQ @tyrnnsrs @Sparky Clearly understood. I will focus on a wired option.
Just use the fm transmitter function in the op1f
You can use any Bluetooth headphone you like with your smartphone. It is easy and it is in the manual.
Wireless is possible!
