I know this topic has been done a few times. I have read all the posts and watched all the videos. I simply cannot figure out how to sync the midi clock for the two devices over usb. I am using an apple usb-c to usb-b adapter to connect them which should be fine. I set the midi channels on both, set the midi settings on the op-z (I’ve tried all permutations), and set the sync mode on the op-1 (again I’ve tried them all) but still no luck.
Does anyone have a comprehensive guide to troubleshooting this? Am I missing something ridiculously obvious? Is there a fault in one of the machines?
Thanks for the reply! I am getting nothing. No clock, no ability to play notes, nada. I am probably going to get a usb midi hub to make it work as that seems like the best way.
your OP-Z should also briefly highlight the last step when plugging in another unit, you may swap the cable and turn both units on, then connect the OP1 to the Z.
I’ll keep trying. I’ve monitored outgoing midi from my mac and both devices are sending the clock and I can control both devices from my mac. So it is odd that they won’t speak to each other…
The cable must be checked! Went through mine last night and found 2 that worked (with Apple USB-C to USB-A dongle, aka CCK; both of these cables have the lump in the middle that is a iron ring/noise suppressor ) and 2 that didn’t (sadly, the “official” TE usb cable that came with the OP-1 was one of these!)
Turned off USB charging on both the 1 and the Z and hooked up the OP-Z 1/8” audio out into the OP-1 line in - by setting MIDI channel appropriately, could play desired channel of the Z from the 1 and sync worked both directions, yes!
Excited to use the OP-1 and OP-Z together on longer train rides now (finally!)
I had no luck with the Apple USB-C to A Adapter and the official TE-Cable, so I bought a USB-C to micro cable from URGREEN (at Amazon). Just read the description, like others said: Must be power and data. And turn your devices on before connecting them. That worked for me.
