Im just beginning to learn the looping on the OP-1. I have encountered a problem.
Oh and if i cancel the loop during playback with shift> i lose the first loop altogether. When is see DJ Thomas White video he only uses 2 bars for his track. I want to do 32-64 bars with multiple loops coming in and out.
Sorry bad English. I meant the only way for the track to progress past 2 bars is Shift> which loses the 2 bar loop on track 1 which i dont want to lose
Copy the 2 bar loop as long as you want it to play. You can’t loop sections of each track independently, it’s supposed to mimic tape.
Ah thank Anfim. So each time i want a new loop i lift and drop the old one or create a new one as the track progresses. The mimmicking tape makes sense. I didn’t think of that. Can i ask then is the OP-1 loop better in live play and if i’m not doing Live play i don’t need it?
But this would be a good feature being able to loop diffrent section at a time, especially for live!
Yea i understand live looping its a great feature mixrasta. As it makes it interactive and FUN. So much to learn
Im a bit out of my depth at the moment. I’m only used to sheet music.
Ah thank Anfim. So each time i want a new loop i lift and drop the old one or create a new one as the track progresses. The mimmicking tape makes sense. I didn't think of that. Can i ask then is the OP-1 loop better in live play and if i'm not doing Live play i don't need it?
I have used the OP-1 to play back prepared audio loops, alternating between Track 1 and Track 2, in live performance.
