Hi, I have a major problem with op-1.
The problem is if I put the sample that I made to the op-1, the sample came out from the op-1 synth sample as +3 tuned up.
I work with the Cubase 9
In op-1 synth, when I insert the exported sample from the Cubase, it comes out as +3 tuned up.
When I put the sample that has an exact C pitch in op-1 and press C note, the sound of the pitch in D# will come out on Synth sample mode of op-1.
I have tried to format as aiff 44.1khz 16bit and 44.1khz 24bit, but I got the same result. the problem has not solved.
But there is a weird thing. If I put the same sample that I made on Cubase, into the drum sampler, the original pitch came out right.
There is another weird thing, when I put the samples that I downloaded (not the samples I worked on myself) It came out from the op-1 synth sample with the correct pitch.
I’ve already gone through several formats, but the problem isn’t resolved.
How can I solve this problem?
and Is there anybody who can talk in Korean?
