::How do I? (The Q & A Thread)::
Korg vocals:
I can’t get proper midi clock sync with Beats and Keys hooked up to my iPad running Cubasis. I’m running it all with my Itrack Dock and usb to midi din cable. The Volcas are way too fast compared to the tempo running on Cubasis.
Anyone else encounter this?
@Kites have you got another drum machine that you can sync to midi? I’ve got a monotribe with midi mod that runs at double tempo when clocked.I send it a drum click from a short snare sample off an electribe into the analogue sync and I can choose my divisions. Hope this can help.
@Kites have you got another drum machine that you can sync to midi? I've got a monotribe with midi mod that runs at double tempo when clocked.I send it a drum click from a short snare sample off an electribe into the analogue sync and I can choose my divisions. Hope this can help.
Ya I was thinking of trying the monotribe sync app as a last result.
Super noob question (got mine yesterday eve)
I’ve been messing around with he pattern sequencer, and recording in ‘live’ / hold mode. Is there anyway to have a metronome on while recording this? At the moment I’m making my own click track. The metronome only seems available in tape mode - is that right?
Thanks in advance :slight_smile:
@OllyV Wow I totally forgot about this thread! Thanks for seeking it out and inquiring here.
The metronome works in pattern sequencer too, but you have to have your tape running as it syncs to tapes transport controls. Usually I’ll run an empty loop with the metronome on, get into the sequencer, count along with the metronome, and engage the hold mode where I see fit.
I think there’s another option that will trigger the sequencer from your recording or something, too tired to think…
Hi all,
loaded with a noob question - think im posting in the right place? or should I be posting this as a new subject in the help section?
Is there a way to latch a key press? i.e. instead of having to hold down a key - a function to press a key and it to hold that note until i press a different one/change presents/something else.
I’d like to use the OP-1 for more live droney stuff, but at the moment im finding myself holding a single note whilst performing finger-acrobatics to try and press other stuff nearby without letting go of the OP-1.
Ordinarily i’d just tape the key down, but that ol chestnut doesn’t work with the fancy OP-1 design :slight_smile:
perhaps I could balance a small metal brick on the key…
p.s. I know I can sequence a single note in Endless and have it loop around - its almost what i need it to do, but no good for long droney evolving note tails.
Cheers for the answer! I figured it out the next day - pretty simple simple really, thought I’d tried that. A lot of things that had me scracthing my head have started to become clear. Which is pretty good going in under a week; shows how intuitive the UI is. Thanks again for rpelying!
Hi all,
I'd like to use the OP-1 for more live droney stuff, but at the moment im finding myself holding a single note whilst performing finger-acrobatics to try and press other stuff nearby without letting go of the OP-1.
Ordinarily i'd just tape the key down, but that ol chestnut doesn't work with the fancy OP-1 design :)
perhaps I could balance a small metal brick on the key...
I add the notes in sketch sequencer. Define where you are drawing by pressing the key and make a horizontal note the length of the grid. Can’t remember if the envelope retriggers at the end, but if that is a problem then reduce the tempo waaaaaaaay down and it should latch for a good long time.
Or get an assistant to hold it down for you!
yes almost as soon as i posted my question I discovered this sketch sequencer trick. Reading skillllz.
again its alllllmost what I want. its great for holding a single note (almost) infinitely, but the thing about latch/taping the key down is im free to move to a different note/add new notes to it on the fly. Guess can still do this with sketch, its just a little fiddlier.
Shame there isnt something simple like Shift + Note = latch.
suppose i’ll have to get Jeeves to hold the notes for me.
@lewis i’ve always been a bit sad the op-1 can’t sustain notes in such a way and agree something like shift + note + latch would be awesome.
Probably not gonna be included in the next update
pretty good solution in the meantime though @ghostly606
@Nawi77 @lewis At work at mo so can't test, but you can also tie notes on the endless sequencer (by holding the note and clicking ">"), set up 64 steps of the same note and then latch the sequence using the red dial. This way you can change the pitch simply by hitting a new note. Should work.
What are everyone’s general compression tips for cleaner dynamic sound? How much do you drive and release?
I’ve noticed in the battles, that people have more polished tracks.
What are everyone's general compression tips for cleaner dynamic sound? How much do you drive and release?
I don’t know that my tracks are “polished” per se, but 80:80 is the magic comp-bo for me!
So I’ve had my OP-1 for about a month now and my only question from day one is this: is there a way to change the pitch for all the slices in a drum sample (simultaneously)? Changing them all individually is very frustrating and inhibits experimentation.
@sammyjams Noted, thanks. Wow my release has always been around the teens, wouldn’t have thought to go that high. Are you getting distortion? Or is that your intent?
@LaughingAnimal good question, there are probably a few work arounds to changing pitch, but at the top of my head, you can easily change octaves of your drum kit and synth by hitting the Forward [>] and Rewind [<] controls when your in drum mode. Not exactly as precise as pitch, but just letting you know incase you didn’t.
I know you can record your kit to tape and change the speed while turning the white encoder, but in return you’d have to record that to album, load it back onto to tape, and finally back into your kit… Tedious I know.
A daw might be a quicker and a cleaner way. Transfer it over USB and then back.
I’m sure the senior members have another way. Stay tuned.
My first instinct was to totally overkill with the drive, just because it sounded so ridiculous, but I’ve eased up a bit lately. Sometimes it messes with your bass balance too much. Cool shit happens at long release times, but it also sounds less punchy.
My recent battle track I did a 50/60 drive setting, and it worked pretty well - I tried it with a lot of different settings. I think there was still a sort of limiting going on, but it sounds heavy, yet crisp. It makes a big difference when you bring your levels down in the mixer first, so the signal hitting the drive isn’t so hot - give it some breathing room. The drive sounds tighter and a bit less crunchy that way, IMO.
@wingo really great tip, i’m trying this all out now. You guys are driving harder than I expected, does that mean your L and R levels are much lower?
I’m experimenting with my recent Deco purchase, POs through Mini Kaos Pad 2s > Deco > OP-1. Seems like the Deco damping the signal, sadly.
So I've had my OP-1 for about a month now and my only question from day one is this: is there a way to change the pitch for all the slices in a drum sample (simultaneously)? Changing them all individually is very frustrating and inhibits experimentation.
If you use the pattern sequencer the pitch changes across the keyboard as would happen with a normal synth. No way to change all the actual settings in the drum sampler at once as far as I am aware.
@sammyjams Noted, thanks. Wow my release has always been around the teens, wouldn't have thought to go that high. Are you getting distortion? Or is that your intent?
Sort of like what @wingo said, I keep some headroom in the mixer. Always a must when using compression. Overall LR output at 94.
