Hi,
I owned the op1 very briefly and did not actually check if it were possible to record external audio to tape for longer periods than op1 can sample?
Can someone enlighten me as to if/not this is possible?
Thanks
Hi,
Thanks
u can record to the tape the entire duration of the tape
u can slow the tape down to get even longer times
I think it’s 24 minutes at the slowest speed 1:4.
yep the absolute longest contiguous recording on the field is 24 min
So, the recording quality also goes down then? Or does it stay the same (in the ballpark)? When u record to slowed down tape
it gets worse, definitely. it becomes very lo-fi.
