Hi,
I bought a OP-1 a couple of days ago and I’m still learning it. I’d like to know how to save a song ? I guess it’s with the COM option right (I have to learn it, if so). When accessing it, is it possible to still access the different tape tracks ?
Is there such thing as multiple projects ? I guess you have to use the tape and then change the tempo for each new song ?!
Yeah the COM option turns the OP-1 into an USB drive, you can access the album sides, tape tracks (as AIFF files), and synth and sampler presets (not the factory ones though). You can rename the snapshots on flash disk and give them proper names, they will be shown in the OP-1 UI as well. Also you can create folders for your presets.
i’ve been wondering (and maybe this info is available somewher). but is there away to back up your sequences? finger and endless and all that?
i've been wondering (and maybe this info is available somewher). but is there away to back up your sequences? finger and endless and all that?
Afraid not. All you can do is scribble down your sequences on a piece of paper…
You can always record them into a MIDI sequencer…
So if I save a song to the album can i call it back up to continue working on it later or is the album a “final” bounce of all tracks? If I export the project files to my mac is there a way to bring them back in to continue working on it later? via sampler? just got my OP1 and Im still trying to understand this thing… thanks!
Album is a full bounce - like bouncing out of a DAW.
