I recently got my hands on a june-60 Chorus and I’m not sure how to go about it. I have a single wire interconnect 1/4 in ts to 3.5mm trs,is it the good one? How do I plug everything in? Sorry if it sounds simple, but I really don’t know anything about it and sorry for my bad english
Thank you!
That’s awesome, the June-60 looks really cool!
Yeah that sounds like it should work, have the output 3.5mm cable from the OP-1 go into the input of the June-60, then you’ll need another 1/4 cable to connect the output of the June-60 to an amp or a speaker of some sort. Unfortunately you wouldn’t be able to have the June-60 work without plugging it into a speaker as the OP-1 doesn’t have an fx loop. But an external speaker sounds much better than the internal OP-1 speaker anyway.
Looks like the June can run off battery as well, or you’ll need a power supply of some sort. Typically battery powered pedals will turn on when a cable is plugged into the input, so if you go the battery route remember to unplug the audio cables so the battery doesn’t run dry on you.
Hope this helps!
Also, just thought of this but not sure if it works. If you run the output of the June into the mic input of the Op-1 it might work to have the audio come out of the internal speaker. Not sure if this works but it could bypass external speakers.
Anyone try this?
if u plug it straight in u will get a nasty feedback loop
there is way to do it, it involves a splitter cable and panning your channels hard left and right
to get the proper separation.
there is an old thread on here about it.
i used to have a diagram i made too but i seemed to have lost it.
it also only works on stuff u have already recorded onto the tape
u will still get a feedback loop with live audio.
i use this technique alot actually.
