interesting, i’ve thought about doing something similar
thanks for sharing!
edit: surprised to say this was pretty accurate and fair, if i know anybody looking for a sampler i’ll definitely refer them to check it out
when i checked the description w/ timestamps i was hoping you’d cover build quality too (which i think is important)…i’m glad that was part of the “bang for your buck” roundup for each machine
I will say though that the build quality on all of them is pretty solid - time will tell about the OP-1 field though- i’ve only had it for a second. If I was to choose which one had the most solid build quality though it wuld be the digitakt for sure.
the octatrack looks interesting…although a bit intimating.
I’d rate my samplers in this order
1/Ensoniq ASR10
2/ Roland MV8000
3/ Ensoniq EPS
4/Yamaha SU700 (this thing sounds incredible, but is only a phrase sampler)
5/OP1 OG
6/Casio SK200
Although the OP1 is at the bottom of the list of samplers, it’s my favourite for sequencing, recording and arranging using the 4-track tape. I use the ASR10 for sampling and effects, then mdi it up to the OP1 for sequencing, recording and arranging everything on the OP1s tape.
