Man, it even does vaporwave!https://www.youtube.com/watch?v=SHOGh8-NBV8Awesome vid ! But it’s only tracks processed through the octatrack filters/effects, isn’t it ?
No idea, could be a combination of both.
Sampled (live recorded, even) and trimmed an old synth pad line me and my bandmate found lying around in our old Ableton projects, put a boom-bap over it with the stock drums, and hey, a first real beat. Starting to understand the basics now.
Static basically free up the memory…
You cannot normalize the sounds though.
Now you can sample, save as new flex, do your manipulations then use your sample as Static.
In general, your samples will already be fine so use static as much as you can, no memory limit
soundcloud.com/hismostdarxxxellent/darxxxecrets
This version differs from the other I posted, I rounded off some rough edges.
I just got my octactrack. Slapped this together yesterday with some sampled guitar.
Nice and mellow, nicely done ![]()
Thanks. Pretty fun machine.
Nice work, y’all.
Are you using a p-lock on the second pattern or changing the sample on the playback window?
Nice work, y'all.Noob question: In the second pattern of the song I'm making, I re-use a sample (a synth pad) and layer it on top of the original sample but pitched down to -4.0. When I switch back to pattern 1 the pitched-down sample plays for a little bit, but the original sample does not. Is this a time stretch issue?Oh, and I fully intended to do more sampling tonight but I got home late from work and was too fuckin' tired to even try. Tomorrow night I'll plug in my Pocket Operators and OP-1
Track samples play til their end when switching patterns (or they continue to loop if loop is activated) unless a trig on the active pattern kills them. Maybe that’s what’s happening? There’s an option for’ tracks start silent’ that changes this behavior. Or you can just p-lock the level to 0 on the first step of the pattern.
Not totally sure that this is what you mean but hope that helps?
It’s the same sample on a different track which I changed in the playback window
Nice work, y’all.Noob question: In the second pattern of the song I’m making, I re-use a sample (a synth pad) and layer it on top of the original sample but pitched down to -4.0. When I switch back to pattern 1 the pitched-down sample plays for a little bit, but the original sample does not. Is this a time stretch issue?Oh, and I fully intended to do more sampling tonight but I got home late from work and was too fuckin’ tired to even try. Tomorrow night I’ll plug in my Pocket Operators and OP-1Track samples play til their end when switching patterns (or they continue to loop if loop is activated) unless a trig on the active pattern kills them. Maybe that’s what’s happening? There’s an option for’ tracks start silent’ that changes this behavior. Or you can just p-lock the level to 0 on the first step of the pattern.
I’ll probably end up just putting a silent trig on the first pattern so that the track doesn’t keep playing. Or figure out how to mute tracks on each pattern since the problematic sample is on track 6 or something
If you don’t want the tail of your sample to be heard on another pattern, there are numerous possibilities :
I’ll figure something out, thanks for all your suggestions. Still early stages with this thing, after all. Haven’t even used the different kinds of trigs yet or made my own drum kit.
One-shot trigs are pretty cool for creating fills : you activate them on one track by holding the track button and hitting yes.
this is sick
One-shot trigs are pretty cool for creating fills : you activate them on one track by holding the track button and hitting yes.You can place a one-shot trig by holding Fn and hitting a trig. Look for the "one-shot trig" chapter.It's especially useful for sampling : most of the time, you'll want to sample a loop only once.To achieve this you use on the recording track, guess what ?a one-shot trig !!:DVERY useful feature.Drumkits are cool, but you can find plenty on the internet that are balanced well and conceived for the OT (basically, 64 samples placed regularly).What is really fun, I found, is more sampling a loop you did on e.g. a Volca and mangle it beyond recognition ^^
Yeah, I’m going to sample my PO-12 tonight I think. Should be interesting.
I just got my octactrack. Slapped this together yesterday with some sampled guitar.this is sick
Thanks.
Sampled some PO-12 stuff into Orochi (my cute nickname for my Octatrack) tonight. Tried slicing up a full loop which didn’t go so well so I just made a pattern on the PO with each step being a different sound and sliced THAT up. Also didn’t go so well since the kick drum was clipping and the noise sound on the PO bled into a few of the other sounds. Live and learn, I guess, and also the pattern on the PO with each step being a different sound, all in order, is pretty groovin’ actually so I’ll keep that one for later.
I figured out how to reverse samples. FEAR MY SWOOSHY REVERSED SNARE
Hey @Jellygeist have you tried the layer clap or block on accent snares for better snares trick? Then effect both tracks similar .
Also micro shifting triggers page is really good for looser feel. I think its hold trigger and < or > ,but not sure.
