You can also record unquantized in the sequencer - something that’s not advertised much. Search for quantized/quantization or similar in the manual. After that they can be quantized in something like 33% steps, which is nice.
Hey @Jellygeist have you tried the layer clap or block on accent snares for better snares trick? Then effect both tracks similar . Also micro shifting triggers page is really good for looser feel. I think its hold trigger and < or > ,but not sure.
That’s indeed what it is. Very nice trick, thanks for pointing it out!
Hey, the track is finished:
https://soundcloud.com/capsule-kids/to-slide-on-glass-mountains
Word to the wise: Don’t move samples around in the file system. I done gone and moved the synth pad I used for the above track and now I have to rebuild the song. I mean, it was recorded already so there’s that, but I wanted to keep it around anyways.
@Jellygeist if you need a tool for file management, consider getting Rusty’s OctaEdit
@Jellygeist if you need a tool for file management, consider getting Rusty's OctaEdit :)Really love this track !!
Thanks! It’ll be fun rebuilding it to see what happens and hey, maybe it’ll be better.
I looked at OctaEdit and it seems useful but it's 99 bucks. I'm sure it's worth that much but I don't feel like spending that kind of money at the moment. Thanks for the suggestion though!
You can try to win one licence ![]()
Was in a bad mood so I didn’t do too much with Orochi tonight, but I at least switched it on and mucked about a bit.
A sample will not load in FLEX RAM if you have used all the space.
Do you have the same trouble with STATIC machine ?
Send the link to the sample, if answer is yes
A sample will not load in FLEX RAM if you have used all the space. Do you have the same trouble with STATIC machine ? Send the link to the sample, if answer is yes :)
Yeah, I was trying to load it into a STATIC machine
A sample will not load in FLEX RAM if you have used all the space. Do you have the same trouble with STATIC machine ? Send the link to the sample, if answer is yes :)Yeah, I was trying to load it into a STATIC machine
Here it is: SAMPLEI have a suspicion that it might be the bit depth. It’s 32 bit which I have never seen before and I really doubt the OT can handle that.
Haha, I have seen 32 bit before, what am I talking about. Still don’t think the OT can handle it.
Iirc OT only eats 16 and 24 bits
You should convert your sample.
Iirc OT only eats 16 and 24 bits :) You should convert your sample.
Yup, I did before I went to bed and it worked. Now to figure out how to make it play the whole thing in 64 steps. Isn’t there are a way to time stretch it to do so?
Yes there is.
First thing I was indicating is where you set the timestretch algorithm (OFF / NORMAL / BEAT)
First thing I was indicating is where you set the timestretch algorithm (OFF / NORMAL / BEAT)Manual says "If the TSTR parameter in the FLEX/STATIC PLAYBACK SETUP menu is set to AUTO, different timestretch settings can be applied to different samples used in a track."So... You also have to look into the manual I guess :D
The manual is actually pretty well written, it’s saving my life. Thanks for the video, too.
To hit beat, I advise to use Slice mode if using a sample chain, or slot mode, which is fun as well.
Used slices a bit, really like how you can resample a whole 64 steps of drums and use slices to introduce the variations.
You can of course have a different lengths for all pattern.
You can of course have a different lengths for all pattern.And you can even set a different length for each track inside one pattern !Unfortunately you can’t direct jump from one pattern to another.But you can program weirder thing in the Arranger (check this once you master the rest
Already used the Arranger in a limited way to make To Slide on Glass Mountains. Looking forward to using the BPM changes and other craziness! Thanks for the tips, too.
