Make sure you haven’t left the gain set high. either in the mixer or at the audio input. EMail TE I would imagine they will sell you the board. replacing it is easy.
Yeah, I emailed TE. They don’t have connector boards available currently, and I suspect replacing that wouldn’t fix this anyway. Those boards pretty much just have the physical jacks on them. The amps and the rest of the interesting hardware is on the main PCB, which they don’t allow you to DIY replace. I would have to send it from Boston to Sweden for them to inspect it. Ouch!
Thanks @cloudburst
Hi @borden, I’m sorry you’ve got such a problem.
Maybe you could record that ghost sound and share it with us
I have this same issue. One day my internal mic died and I noticed the noisy input.
But I’m not sure if its was always this nois and maybe I hadn’t noticed before.
Would love to hear a sound example, as the OP-1 is known to have various noise issues. Try a factory reset, maybe run a function test and see if anything fails.
My op1 will hiss and squeel with certain settings. I find cwo can be very noisey and the d synth engine. I consider it perks lol.
After playing around for a few weeks I’ve come to the conclusion that it’s probably always been noisey and I didn’t break anything. I normally have it plugged into some monitors, and the hiss isn’t noticeable like this. When I use headphones I notice it, but it’s not really a big deal.
When the compressor is on even a tiny bit its super noticeable. High whiney pulsating static.
Yeah, same for me. It seems tied to the compressor.
I might record an example of the hiss at some point.
please do.
