I wish there was an option to disable headset mic input on op1f, it comes on every time you plug in headphones with a mic, but the internal mic on the op1f is so much better.
Almost all 3.5mm earbuds have a mic now so this is pretty annoying. I wish there was a way to select op1f mic as the input.
To work around this I’ve been carrying a headphone splitter that only had trs rather than trrs so that the op1f can’t see the mic, but that’s a bit of a bore!
Has anyone found a better workaround?
