I'm going to design a keyboard replacement for OP-1
Hey all,
I am an owner of an original OP-1 with keyboard issues like many others, and it seems like the replacement part has not been in stock for a long while now. Makes sense taking the age of the device into consideration.
As someone who is vehemently anti e-waste I’ve decided to go on a long term journey to create a replacement keyboard part for the OP-1, and my goal is to make it accessible and repairable as possible.
This is a big task, and I wanted to ask on this forum is there would be interest in this project, and suggestions as the project progresses. Thank you in advance!
Kudos
I’m an OP1 owner with no issues but I’d love for there to be a long-term option to keep my instrument operating well
I’ll keep an eye on your project and spread word to other operators who might be interested in buying or offering feedback
I’ll post my progress on this thread, feel free to drop comments or suggestions.
The beginning of this project is to figure out why the keyboards fail, and the answer seems to be pretty straightforward. The keyboard membrane consists of thin traces leading to its connectors, some on top of others. After many uses the traces seem to slowly deteriorate, cutting off inputs from the key presses. That seems to be the problem for my keyboard at least, let me know if other issues are observed. Below is a rough draft of the traces. Yellow layer is the bottom layer, blues connect a few of the traces together by overlapping other traces. The red traces are folded over onto the yellow traces so that the contacts will meet when the keys are pressed.
I assume the keyboard was designed in this way to keep the profile as thin as possible, and this was probably the best solution for the time. 10 years later and technology has advanced, focusing on mechanical keyboards. Laptops and macbooks have been known for their thin keys (whether you like them or not), and we are now able to build mechanical keyboards in a similar fashion. Many companys such as Cherry MX, Razer, Corsair, and other more niche keyboard companies have created keys made for a thin profile.
The reason to decide on making a mechanical keyboard format is the ease of repair. Traces like the current OP-1’s keyboard design are very thin in order to fit all of them on this small layout, so they will naturally decay with more and more use. Mechanical keyboards are much more easily fixable. PCB’s are much less prone to damage, and with the ability to remove and replace smaller parts that are soldered onto the board, hopefully this project will help the OP-1 last for many many more years.
First step is to finalize all the pin connections, then get to designing. Thankfully membrane based designs like these are relatively simple in terms of how they function, so I hope I can find a design that works soon.
Please let me know your thoughts and suggestions!
very cool this is an awesome endeavour! Will be following your progress and happy to help any way I can!
You are a legend! I hope this works
Amazing idea! Really looking forward to seeing new updates and on this. Good luck with the project.
I’m totally interested in that project!
A replacement keyboard would find it’s customers for sure!
And i would be one :slight_smile:
Maybe you’ve progressed past this point by now, but I made a tool for helping repair the flex PCB and it includes the full pinout of the two connectors, not sure if that helps you.
Your graphic was helpful in tracking down the differences between the two versions of the flex PCB and drawing the layout, so thanks for that.
I’ve just posted about about my tool here:
I’m very curious and interested to see how your progress is going on this project. Spilled a little beer on my op-1 keyboard, sent it to Triple S for repair and they were out of replacement keyboards.
YES, YES, YES have a bricked op-1 that I had a month after spending 1500 on it. Such a sick feeling and a letdown. It just sits collecting dust because I can’t mount as a drive so cannot update firmware and can’t seem to find any help except re-order parts, without any explanation of what went wrong in the first place. It just out of the blue stopped mounting. So Frustrating. .
@Ethanfide
If you make it I will buy it. Many if not most OG-1 owners should get one too.
Im sure I will buy it when its released
Oh yes! I will buy a keyboard for sure!
Nice, I will buy one, too…
likewise!
Hey! this is a wonderful idea. Do you need any help? Maybe we can support you/crowdfund this! Cheers
Since there isn’t much traction I would offer to try to give this a bit of help. I would kindly ask anyone that has existing material (cad files of the keyboards, detailed pictures of v1 and v2) to provide them here so I can collect them and try to get this off the ground.
I reached out to pcbway to see if they would be willing to help us in the design and material choice for a replacement keyboard using existing scissor mechanisms and keycaps.
Is there anyone in here that has a broken/sacrificial op-1 keyboard (v1 or v2) that they would be willing to either measure and photograph or send it to me? I’m willing to pay shipping. I would need precise measurements of all sides, placement of ribbons and, ideally, detailed pictures of the placement of the switch hinges on the keyboard. Mine is functional again after repairing a trace but seeing the inside of it I think the only viable way to keep the original working is to design a new keyboard because the traces are insanely fragile and now I’m afraid to even look at it wrong.
Yeah I have one and calipers, is there particular measurements you need? Obviously it’s such a complex component, there’s many parts to measure.
