When copying a ‘Track’ .wav file into a tape folder I experienced an odd bug. The track file plays in the tape but does not show up as a region visually, so can’t be edited further.
This happened when I recorded a mixdown to side A, then using a laptop, I renamed the recording as “track_4.wav” and dropped it in a tape folder on OP. When opening that tape I can hear the track properly, but it is not showing up graphically in the OP-1f interface.
Curious to hear if anyone else noticed this, and if there is a known way to fix it?
On the other hand, is there a way to import the mixdown into a single tape track without involving the laptop?
I was trying to capture something that was coming out of the tape which is playing at significantly lower speeds, and somehow couldn’t wrap my head around how to not have that captured exactly at the same speed as the initial recording… still unsure how to accomplish that.
In any case I was hoping there was some way to “lift” the record content and bring it to tape or sampler (the way lifted regions can be dropped into sampler for example).
