Installing sound pack doesn't work - the folder with the presets doesn't show up
Hey everyone!
Hope that someone has any tips - I haven’t been able to make this sound pack show up on my XY: Colors In Space OP-XY (Free Drum pack)
I’ve copied it with FieldKit to presets folder, alongside some others that I have got and bought. But this one just doesn’t show up.
I’m on 1.0.38 firmware btw
Hope someone has tips! I tried twice with this soundpack. The author also doesn’t know why, albeit he was super helpful in responding fast. If the forum won’t help, I’ll message TE but I just hope someone knows anything and will respond, cause I feel like TE will be very slow about this.
Thanks <3
Have you tried copying the folder and renaming it? Just it see if there’s a problem with the folder name.
The whole folder could be somehow corrupted so if you can, perhaps download it again if possible.
I’ve had samples not show up before but that was because they’d got characters which weren’t allowed in file names. As this sample pack appears to be made for the OP-XY then this shouldn’t be the case.
Hope you get it sorted
Thank you for kind response! I ended up making it work by renaming the soundpack from colors-something to just colors. I have no clue why, but I’m keeping the answer for any others who may face a similar issue.
I have another soundpack that has - in the name of the folder, so that’s not just that. I really have no idea what happened but am glad it sorted itself out.
Hi. You’re welcome. Glad you got it sorted. I think it is the hyphen symbol that caused the problem. I had a bunch of samples I had to batch rename to remove it from a load of Splice samples.
That was in an earlier version and I did think that they had added the ability to read more types of characters in an earlier update. Maybe the hyphen wasn’t one of those characters.
Anyway it sounds all good now you got it fixed :+1:
I have problem to rename Path then it is in OP-XY, Solution is to rename in your PC first then copy all to OP-XY
Funny I was having the same issues with some of my soundpacks on the latest firmware. I’m thinking it maybe a bug cause I never had these issues before.
