Hello
Do you have same problem with irig 2 input level ?
The level is very poor
I connect circuit track output (headset or direct output)
I connect to irig 2
Screen + 2 on op-z
Screen + mixer for max the level input
I scroll all the way the master of irig 2
And master volume of circuit track to the max
All is maximum level
But level of input is very poor, i must lowered all tracks of op-z for a great balance
Some tracks to 10-15 level in mixer for great balance
Do you have any tips for increase ?
Thank you
Sorry for my bad english
Did you press screen + mixer multiple times until the green LED reaches the last step on the sequencer (motion) track?
Yes !
Screen + mixer with the green led to maximum right
I have receive a simple split trrs cable today and it s work greater than irig 2 it s 30€ cheaper
And now i have enough volume
What s wrong with the level of irig 2 ?
Irig 2 return to amazon
Does a trrs cable automatically turn any input into mic level?
I’m worried about plugging anything (eg my mixer) into the audio jack to sample from in case it damages the op-z. But I do have a minijack to trrs cable (for my microfreak vocoder). Would that work to reduce line level to mix level?
a cable itself does NOT change the signal levels to different ones
it won’t match the impedance either.
Ok thanks for clarifying. Still need to wrap my head around impedance.
