Hey everyone,
Hey everyone,
As long as the mic doesn’t require phantom power it should work as you described.
The OP-1 records in mono on each tape track, but records stereo input in album mode.
Can you lift/sample from the album content (in stereo) ?
As long as the mic doesn't require phantom power it should work as you described.
You need a self powered mic. Like one with a battery in it. I’ve tried any passive mic does not seem to work.
You can’t lift from album, but you can route the output of the album to tape / to drum / synth sampler. It will be summed to mono
Thanks for the info.
The OP-1 records in mono on each tape track, but records stereo input in album mode.You need a self powered mic. Like one with a battery in it. I’ve tried any passive mic does not seem to work.
So a normal Dynamic Mic won’t work? Maybe through a Pre-Amp…
I’ve used a normal dynamic mic…
I’ve used a normal dynamic mic...
and it worked fine?
I use the rode nt3. It can also be battery powered and is a very low noise mic with an excellent sound quality. It works nicely but the low quality preamp of the OP1 is still obvious. .
I’ve used a normal dynamic mic...and it worked fine?
Shure SM58 > XLR Female to Mini Jack > OP1 record in
