Hi all,
There’s no way such a tiny speaker can render bass, one would need a bigger speaker for this.
That’s good to know, if that’s just how it is then I can deal with it, just seemed like it could have been busted. Thanks!
I can hear bass on my speaker, but maybe these patches are sub sinus ones without any high or mid frequencies…
Hmm. Can anyone confirm either way with those presets?
I can’t check cause on beta OS but worth checking you haven’t eq’d the higher frequencies out in the mixer section.
Did a factory reset just to make totally sure it wasn’t a weird setting somewhere, but nope, still the same.
Can’t you just tweak a bass sound with Pulse maybe. You should be able to hear this. I don’t have my OP-1 here for a check.
I can't check cause on beta OS but worth checking you haven't eq'd the higher frequencies out in the mixer section.
^ This : go to Tape > Mixer EQ section and ensure the Bass isn’t the lowest.
I’m on the beta and some of the bass sounds are super low sines that don’t come through the baby speaker. You’re probably fine. Or mine is broken too.
These damn sines!
