I want the P1 and P2 parameters to change over time. Is there any way to achieve this? Thanks
Is there any way to record synth parameter settings?
zer0_0ne
#3
Found a way to do it. Pretty basic actually. Hold down the note and turn the parameter dial.
Rumte
#4
You can also hold record while the pattern is playing and turn the dial to record the changes. Also: Hold record and stop deletes all parameter automation iirc.
LyingDalai
#6
You can also use the MIDI LFO and control the OP-1 from outside (with a computer or a Digitone for instance)… This way you can have 4 simultaneous LFOs !
