Issue with Copying Steps & Manually holding down keys while pressing desired step
I’ve got a longer phrase, chord progression, and I’m trying to copy steps around. It’ll work sometimes, but then I’ll get to one step and it’ll crash. Have to power off and restart. (Newest update 1.0.21 doesn’t fix this occasion copying step crash)
Additionally, If trying to avoid copying to a step, this same step giving me issues won’t allow me to press the chord I want and then simultainiously press that step… It just doesn’t want to put the notes there…
I don’t think it should be a polyphony issue because of the rest of the progression working perfectly.
help meh pleaase!!
<3
Man, just so many bugs here it’s a little overwhelming.
Crazy reverb clipping smashes when going from one scene to the next… what’s that about?
Also is there no way to copy instrument + mix settings from one scene to another and not the actual parts? I’m working through an arrangement and adjusting the mix, thinking its gonna effect the entire mix, but it only applies to that singular scene and reverts back to old mix / instrument settings for other scenes.
And no automating on/off for hold (or arp/maestro)? seems like that’s gonna be coming.
Deep in my frustration rn, hoping they can address some of this stuff.
Ok continuing the saga here,
I did see there’s a software update out which hopefully address some crashing.
Also noticed that the reverb blip/clip at scene change was due to the width settings jumping. It’s that situation where once you have scenes, you basically can’t do any sound design/mixing anymore because it’s nearly impossible to match exact settings to every other scene for the same sound. So strange. Anyone else experiencing this?
Update didn’t fix copy step crash.
And new bug causing “skip trigger” step component to not work at all. The trigger just skips every time and never fires.
