I would like to get parts of the custom firmware onto my OG. OP1.
is it possible to get only, say, iter and filter fx into the main Synth/drum/master-effect menus and the cool iter-lab graphics? while leaving the rest of the os as it is (#246)?
is it possible to keep usb-audio function from #243 when using custom firmware, or parts?
its pretty much all laid out in the firmware repacker github
but yes u can select which mods u want
and yes nothing else from the actual firmware version u are unpacking and repacking is affected so u will have all the features of whatever version u unpack and repack
Ok sry, my fault was just that I thought I had to put the repacker-folder somewhere first to have python recognize it, which is why my installation attempts failed: All it needs, is an Internet-connection, and it downloads the files by itself as you give the install-command . I used python 3.6.7
I overthought things with implementing an environment.
