HI everybody,
Buddy, it looks like you’re the only other person I’ve seen with this issue. See my vid of it https://youtu.be/cpbGBapn-9U
Currently working at getting this fixed. It’s been a pain. Let me know how you go with resolving it.
I try all the stuff end with no screen it’s not fun. I think the screen is dead, at the beginning i was thinking that is a os problem but definitely not.
You know yourself better than anyone else. If you will live in fear that it will break after the warranty, then it is probably best you buy something you feel comfortable with. I have had mine for 4 years now and haven’t had a single issue. But again, that won’t mean anything to you if your viewpoint has been tainted by getting one of the lemons.
Hmm, return for replacement as this is definitely a hardware issue and not normal, it looks like the connection to the LCD screen is not as it should be, I have seen similar issues with other gear before.
Yes you’re right. And it make me sad because i do great things with it during this week. For me the probleme is that it is microelectro so it can’t be easily repair it. And what to do if i had no warranty?
Darenager, yes i think too. Porbably the connexion between motherbord and screen. But did you notice the screen size is in reality bigger ? It goes under the 1234 buttons and the notes. Maybe that is the problem, because the buttons seems just on the screen.
You can still backup everything on your computer before sending it to TE !
@pluginlust -Do bear in mind that you see posts from people that have had various problems, but the many, many people that have a perfect working unit don’t post to say “mine always works great”!
Mine only had a defect in the internal mic. Was fixed under warranty. Got a temporary OP-1 while mine was fixed. After the mic issue, I never had issues what so ever. Love the instrument as much as the Intellijel Atlantis.
Would be a pity to disregard teenage engineering products altogether. I cant imagine life without them.
The business I own in Colombia, Audiotecna, is dealer for TE, Moog, Ortofon, Koma Elektronik, Ableton and Livid Instruments.
I’ve seen a similar thing happen with other OLED components, caused by a manufacturing defect in the OLED itself (missing or badly mounted resistor on the control circuitry on the OLED). This is something that a) should have been caught in QA of the manufacturer who supplied the component to TE, and b) should have been caught by TE’s QA, where they could have simply replaced the OLED for another. If it’s a cold solder, then it’s quite possible that the fault didn’t become apparent until after the unit shipped and was subjected to temperature changes or everyday physical movement. Ultimately the fault most likely lies with the manufacturer of the OLED, not TE, but maybe TE could do a ‘burn in’ test to check for such faults before shipping items to catch this sort of thing. They also have a responsibility to check the quality of their final builds – faulty components are to be expected, and not passed on to the consumer.
My 2 cents:
<a href=“https://www.operator-1.com/index.php?p=/profile/80/jooga1972” class=“Username” style=“margin: 0px; padding: 0px; border: 0px; outline: 0px; font-weight: bold; font-size: 15px; font-family: “lucida grande”, “Lucida Sans Unicode”, tahoma, sans-serif; vertical-align: baseline; text-decoration: none; color: rgb(66, 157, 168); background-color: rgb(252, 252, 255);”>jooga1972<span style=“color: rgb(37, 38, 30); font-family: “lucida grande”, “Lucida Sans Unicode”, tahoma, sans-serif; font-size: 13px; background-color: rgb(252, 252, 255);”> you’re right.
I bought mine very cheap second hand, it’s still rock solid…
Maybe consider the second hand market !
I consider it. But why happened if with this problem and didn’t have a warranty?
So, I Send it back to the shop and demand a refund. I hesitate a moment but the thing is i’m not ok with the built quality of the product. Do you know the screen is bigger than it is? It go under the key…
So, I Send it back to the shop and demand a refund. I hesitate a moment but the thing is i'm not ok with the built quality of the product. Do you know the screen is bigger than it is? It go under the key...Maybe in the future i will try again with a long long warranty.
Yeah the big screen is intentional. You clearly had a defective unit, can happen with any gear I suppose.
