A bit more in my opinion, but it doesn’t matter
I guess we failed to talk you out of getting one. Or help you talk yourself out of getting one. Heh.
Never ever
I’d consider sending it back in case the screen gets worse . Not a common complaint.Also stop you having occasional vexation on imperfection.
Noise may be a combo of op1 and PC ground loop.Try recording to Album unplugged from comp. then import Aif a/b compare background noise. Obviously double check any master FX or Drive is off .
I get small digital noise ,but totally acceptable - I never record straight to PC from OP-1 stereo out. (Its a mixer preamp or into other gear).
I was sceptical about this machine (mostly because of some misunderstandings). As you know I’ve already grabbed my own OP-1 since then
Sorry guys for “give a rant” in the forum, here is my excuse song
This is my very first track on OP-1 (created on the learning curve) that I dedicate to you as a thank you for your help
Ok, I’m not sure if you can also appreciate to have a chance to listen to this track however
@<a href=“https://www.operator-1.com/index.php?p=/profile/2588/iramrezso” class=“Username” style=“margin: 0px; padding: 0px; border: 0px; outline: 0px; font-weight: bold; font-size: 15px; font-family: “lucida grande”, “Lucida Sans Unicode”, tahoma, sans-serif; vertical-align: baseline; text-decoration: none; color: rgb(1, 115, 198); background-color: rgb(252, 252, 255);”>iramrezso<span style=“color: rgb(37, 38, 30); font-family: “lucida grande”, “Lucida Sans Unicode”, tahoma, sans-serif; font-size: 13px; background-color: rgb(252, 252, 255);”> cool song
@iramrezso cool song :DGlad you're starting to be seduced by this little beast and its very own workflow, and having fun ^^
Thanks man ![]()
