Just got a po-133, where can I find a default po-33 backup file so I can try out the po-33 sounds?
Thank you!!
:smiley:
https://teenage.engineering/downloads
You’re welcome
Thanks for the reply! This actually has a link to the ā€œFrekvensā€ soundpack, but does not have the original K.O. PO-33 default sounds.
Anyone out there with a K.O. PO-33 who can make a backup file out of the factory reset settings?
Can you share a backup of the 133?
Dear friend! this is my original PO-33 backup: https://drive.google.com/file/d/1fyPdatMRk-uBIbNwFbzi8q_LMYB04h5s/view?usp=sharing
@becVision it would seem an authorization is needed to access the file…
(Edit: ok, working now)
I think this is it: https://drive.google.com/drive/folders/1TYMJYKsey5yFyVQA1yVQfUyylo-QRrWQ
Please consider exporting a factory reset of your PO-33!
https://soundcloud.com/erwinried/sets/pocket-operator-backups <- exported po32,33,35
If you do a reset the original factory state will be restored I think it’s Hold pattern and write while inserting the batteries
Thank you! Unfortunately it doesn’t work, maybe because of Soundcloud compression - BUT looks like @becVision got his file posted! Thanks everyone :slight_smile:
Oh I will try to upload it as hi-fi then on the weekend
I got the file so no worries, but I appreciate your effort. Did the Street Fighter one load okay?
(I can’t load po32 or po35 information on a 33, can I?)
probably no? not sure. I need to upload them all again probably because the compression
it works!
I uploaded them again (including yours from the street fighter), I hope soundcloud compressing does not mess them as HD
We need backup of megaman and rick and morty now :smiley:
i think someone shared there rick and morty back up on here awhile ago
megaman is a PO28 robot. there is no backup.
Rick & Morty PO-137 Stereo Boosted.(.wav) : https://drive.google.com/file/d/1OUoPty9gvH6eQCAdBrUsxszoqWSMHl-t/view?usp=sharing
PO-33 original (.aiff) https://drive.google.com/file/d/1gdGiPO4QxpUf9rT54vR-EA_qX0KLAWUW/view?usp=sharing
For some reason when I download the aiff file it says the file is corrupted or is not a valid aiff. Any ideas?
Recharged .wav :wink:
PO-33 original
PO-35 original
PO-32 original
You’re awesome! Thank you !
You can get them from teenage engineering site, but I’ve never been able to get anything but error when I try.
https://teenage.engineering/downloads/po-33
To do this Push write + record + sound and it will be in receive mode [rcv] then use aux cable with full volume and press transfer on the sample pack.
