has anyone successfully used the korg sq-1’s sync-out port to clock the po-12?
i’m using a 3.5mm ts jack from the sq-1 sync out to po-12 input (sy-02) mode and not having any luck.
i’ve measured the voltage on the sq-1’s sync out and looks fine…i can’t figure out why po-12 won’t accept it.
the po-12 works fine if i sync it with the same cable with other pocket operators or gate signals from the sq-1.
thank you.
