Thanks for your clear and noiseless feedback
Now it’s only question, if not to wait some time until opz will catch other (hardware) quirks…
Thanks for usb isolation advices - this led noise is happening while not connected on usb, as you can see on video. I’m trying everything I could on noise issue to rule out my mistake- I don’t like to deal with returns and so on…but also with gear problems.
Interesting thought can be, if the noise is the same as my problem, because I finally tried to connect it via usb to computer and I have no usb loop noise, no matter ON/OFF charging shortcuts (at least no such as on beatstep pro - constant, relatively loud zzzz noise).
Have you tried connecting both USB and line out to your computer? But ground loop depends on the equipment, it may not happen either way…
I haven’t tried usb+line out to computer, my OPZ is on way back with issue stamp on it.
However I looked at opto isolators some of you suggested and I will buy one, it looks like tool generally good to have. But I would like to have good product first, not something one unit do and other not.
I am quite frustrated of such generally “cheap” technical quirks also in lot of other products and making ways how to fool it around when they don’t have any “cheap” sense to be there in the first place.
I’ll wait how will (and if ever) TE respond to my request ticket and based on that will buy again, hopefully unit without problems. I was hoping for such sequencing device from makers of POs, although some (drum) synthesis and sampling from POs would be welcome
Hi. Did you get a new unit, or a response to your ticket? I’ve just received my OP-Z and I have the same issue as you.
Hello,
I choose to refund with argument that unit has problem, to send it to manufacturer. I haven’t get response for ticket yet - but I will post it again. I am still waiting for rebuy.
Please send at least ticket to TE, too, and thanks to speak up. TE needs to know that we users know and it bothers us. And if you’ll ask for replace unit, please return here with results.
Maybe it could be usefull to ask some youtubers about this, too, to be more objective-and to make some more pressure on TE to put some more isolation foil or whatever if it’s not individual unit problem. I asked only one propagator of OPZ and he just pointed me at this forum, but they may speak about it elsewhere. Or not
Finally, TE support respond to my claim, so it looks like the question of “LED noise” is closed. I quote their reply and I hope it’ll help other people, too:
"Thanks for the e-mail. Sorry for the delay
There can be some noise on the OP-Z but in your case it sounds like it might be faulty.
Try performing a factory reset and try different headphones.
We have a 1-year warranty on all of our products. So if you purchased the unit directly from us and are able to provide us with a receipt and a video showcasing the issue that you are having we can send you a replacement unit.
If you purchased the unit from a retailer, then contact them first hand."
Thanks for the feedback!
I just got an OPZ and on my first session with it I noticed the LED noise (not the usb charging noise). I then searched to see if anybody else has noticed this and here I am. So do all OPZ have the LED noise problem? or is it that the ones with LED noise are faulty?
Ehr, as you can read in this thread, there’s some evidence, that excessive led noise is not general, all units problem. But, you can contribute to this issue with asking for replace faulty unit and to let us know if the problem still exist with new unit.
I personally returned my OPZ and still waiting for some budget to rebuy (even that have I find out I can live without it ). If I’ll rebuy, I’ll write here feedback, too.
Important thing is, to write to TE, that you have this problem and you want unit without this issue-more people will give this feedback, (I hope) more probability is, that they will take care of it (in some future?). Also, say this to your retailer, to not give your unit to somebody else (but to send back to TE). You may use this forum thread as reference of this problem, with official TE statement that they also consider it as not normal noise, too.
Good luck and please write back if you’ll have new one.
Hello,
I am having the same problem and can hear the exact same noise as in the original poster’s video when the LEDs are on.
I have only had my OPZ for a few weeks and I love it but this makes it pretty much unusable so I am going to contact TE and Andertons who I bought it from in the UK and get it swapped.
I will report back when I get the new one if it has the same problem.
ground loop isolator.
Hey and thanks for posting. I can hear the noise in your video, too.
I got my OP-Z yesterday and noticed that when using the microphone for sampling, a similar type of high pitched noise bleeds into the recorded signal.
This is an issue that can be experienced with different kinds of electronics and is often called “coil whine”. You can experience it with certain phone chargers, lamps, power supplies, mainboards, graphic cards, etc. and is mostly depending on the workload the device is doing. So the device might squeal when idling, but shuts up when under load or the other way round, depending on many factors. (Some phone chargers are almost inaudible but start to squeal as soon as the phone is fully charged)
It’s a problem that many manufacturers are fighting against since decades and seems to be very complex depending on many other components used in the same system.
This has nothing to do with ground loops, since it can be found on (battery powered) devices without any connection to the mains supply, even with no connection to anything.
For me it’s like partaking in a lottery each time when buying new gear:
Sometimes it helps to buy the same device twice and compare both, keep the better one, inform the dealer and manufacturer and return the faulty one. This is when you’re “lucky” and the reason is quality tolerances in the used electrical parts. If it’s not and all the devices have the same problem, you’re out of luck though …
on the OP-Z you have to deal with 2 things—-USB noise (avoid it by turning off battery charging or charge the battery before use) and the other one is a normal Feedback behavior between the mic and the speaker when the volume is turned up while recording and no line out jack is connected.
try to record something with volume down or put your thumb over the speaker holes.
Sorry but I have to disagree with you here.
This is neither a ground loop, nor a feedback loop problem.
The noise I described can be heard when having the OP-Z not connected via USB (no ground loop) and having headphones plugged in (no feedback loop, since the monitoring happens via the headphones and not the speaker).
So we have now at least four kinds of origins:
Noise that can be heard by holding the device to your ear (LEDs, CPU, whatever might be the cause)
Noise that bleeds into the microphone input due to bad shielding(?) which also gets recorded
A loud(!!) feedback noise that happens when monitoring the microphone input via the OP-Z-onboard speaker which can be solved by reducing monitoring volume, or using headphones
A buzzing/humming noise that comes when the OP-Z is connected via USB and charging which can also be solved by disabling USB-charging on the OP-Z (haven’t experienced this yet, but was definitely mentioned here on this thread)
This is the noise I am getting when recording via the internal microphone (please use headphones):
I gradually increased the the input gain of the OP-Z to make it very clear, but even with 0db of gain, the whining noise is audible.
I understand
It sounds like digital noise bleeding into the input analog signal path. It could be a fault codec IC or some other component, like a supply voltage filtering capacitor. It is a QC issue, TE call themselves “engineers” but don’t seem to be very good at that…
Bolandross, so you don’t have this led noise problem (i.e. noise coming to output based on/reflecting led activity), but have the other?
TE really should take better care of shielding/QC with products which deals with sound.
And please, are there someone who exchanged OPZ after returning based on “led noise” and have unit without this noise? I’m still interested in OPZ, but checking my chances to have noise-free unit
Hey Peter,
when using my headphones, I’m unable to hear the LEDs as you presented them in your video.
I’ll try to test again by connecting the OP-Z to my audio interface tomorrow and see if this changes anything. I have another theory that this might also be due to a different firmware version that you might have had on your device months ago. I updated to 1.2.8 yesterday, which might have changed something … but don’t let me fuel your hopes without having any proof.
Regarding my problem, I’ll contact TE and see what they say.
