This is an awesome thing to have. Thank you for making it and for sharing it!
A couple feedback notes:
1) Is CPU usage higher than it should be? It has my Chrome process running in the 200%-240% CPU usage range.
2) Not sure if this is a bug, as I couldn’t replicate it. Initially when I started using it, even with the Blue Panel set to Off, the parameter it was set to was still being modulated by the LFO. Specifically, I was in Cluster engine with the blue encoder in MIDI LFO set to mod the engine’s blue parameter.
