Interesting observation. Debatable if it should mute the audio or just the midi (as it currently does). All other tracks just mute notes being triggered, not actually the audio (so the tail from a note still sounds even after ‘muting’ the track).
For me only muting the midi works very well, but there will be many people like you who want it to mute audio.
I guess they could make this is an option to toggle in the op-z settings file at least. It would be great on a per pattern option too, perhaps it could be added to the module track interface through a button combination.
Yeah it just seems inconsistent to me that it in the mixer page (the image in my post), changes to the module’s fader DOES affect the audio in level, but muting doesn’t.
To me that’s unexpected behaviour, as I’d expect mute to act as “set this fader to 0”.
But with the other tracks (drums/synth) muting doesn’t set the fader to zero, it just stops triggering notes.
So the current behaviour you describe is actually consistent with other tracks, but perhaps not expected in our mental model or the desired outcome for a lot of users.
I’m sure TE could accommodate both ways of using it.
Like @Mistercharlie says, audio mute should work (although you have to hold Mixer first and then press shift.) It works for the other inputs on the module track so the ZM-4 should be no different, right?
