New user here. I am assuming there is only one FX you can use on the master tape track. Is this true?
Thanks in advance
Thanks in advance
Yes, only one, unless you record to album, then record back to tape using Ear, then re-record with the second effect on master. (Doing that you can chain as many effects as you want, but it’s time consuming.) In OG OP-1 that destroyed the stereo image. In Field (if you have it) it should be relatively lossless.
Thanks for reply! Appreciate the info
