Hello! I’m getting a lot of use but also a lot of headaches from the master track chord progression sequencing feature when trying to put together songs with pattern chains.
If I play a pattern on it’s own it always plays the correct progression, but when I chain patterns it gets the wrong chord for the first few beats of the next pattern.
This happens depending on which patterns i chain together. two patterns might chain fine together, but if i chain a different first pattern to the same second pattern, it will mangle the initial chord of the second pattern.
I’ve tried various things like sequencing full chords in the master track (vs just notes) and adding and muting extra chords in the patterns to make sure it interprets the chords correctly, and sometimes it works, but much of the time it doesn’t and it’s driving me crazy to the point where i’m ready to abandon using the master at all and start just making separate patterns for each chord change which seems like a waste of this (potentially) awesome feature, and of patterns.
does anyone know how to fix or work around this?
thanks
