DMG-01 sync output from nanoloop or lsdj, £5 plus postage, simply plugs into link port, no more chopping up cables!
Note it is only sync output from gameboy, not sync input.
WANT! Inbox!
Genius!!
super elegant. nice job man
Thanks guys!
Also made a sync i/o adapter for GBA/SP models, price for this one is £10
Payment sent!
In the post ^
Does the GBA\SP one work with gameboy micro?
@DOMAIN if you have micro to gba cable or adapter it should do.
Any DMG-07 owners who can solder might find this useful:
Heads up to any NL mono owners, when testing these with NL mono I found a sync glitch bug, I reported it to Oliver and he fixed it, so you want to make sure you are using 1.0.3 or later.
hey is this bug where the sync is 1 step off?
@docshermsticks Yes exactly, there was also a short burst of fast pulses when the first pulse should be whenever the bug occurred. I noticed that sometimes no burst and the sync was fine, but whenever there was a burst it was like the sync pulse was inverted - ie high where it should be low and vice versa.
nice! yea seems to be working fine now after updating
