I love the metronome but a problem. When i add a tape FX like delay it adds the delay to the metronome as well rendering it useless. Is there a workaround as it is needed with the tape FX. Thanks
Really wish TE would split the metronome to its own channel. One that didn’t get recorded during resample/ear etc etc.
Ah so its uses same channel as synths. That explains it. Ive downloaded a Metronome App to do the job. Thanks
AFAIK it has its own channel (not using a tape channel) BUT sadly that’s mixed to the stereo pair that then goes through master fx. I’m guessing they couldn’t afford another mix-down stage after the master fx just for the metronome
I like to believe it’s deliberate so you can actually use the metronome to create additional rhythmic and melodic elements.
I like to believe it's deliberate so you can actually use the metronome to create additional rhythmic and melodic elements.
It’s a pretty funky metronome, after all
