Found an m-audio uno that I must have bought like 10 years ago and never used. Works fine with rest of my setup going -
DAW>KENTON 5>Analog Keys>AK midi thru>M-audio UNO>IPAD beatmaker midi thru>OP-1. Powered USB hub involved too.
But its a pretty tangled route! I’d like to not be forced to use Ipad as a midi thru. Anyone know will a (op-1 sized) USB adaptor on the Uno USB connector work going straight from AK to OP?
Also I can play/sequence midi notes from my DAW with the above setup, but transport doesn’t seem to start/stop OP? Any ideas what I’m doing wrong?
Thanks
Thanks for the info and link tho I’ll check it out
