It seems to me that the module has some issues, and i want to leave the slot open fr better stuff in the future – any ideas? a note, my setup is based around iOS. the powered usb hub is letting me connect/sync.control everything with midi, OP-1 sending clock over seems to work best – if it is slave clock drifts way too much, and if op-z and op-1 are set too send and receive midi, lag with op-1 is awful.
possible solution – get a keystep – basically an oplab, but you also get velocity sensitivity, should be able to use as master clock?
other solution, get a retrokits dealio, rk-005 or rk-006 should play. in this case i wouldnt need to buy another keyboard controller (keystep), but because i currently have no need for cv/gate, this is expensive.
gear:op-z, op-1, POs, keylab essential (keys all work finem some of the slider jump a ton which is obnoious), friends hooked up a digitone and tb-03 the there night as week. currently own no gear than needs c/v gate.
